Periodically, there will be software upgrades for the controlling bridge
(CB) and bridge ports extenders (BPEs).
The CBs run
ExtremeXOS software, while the BPEs run VPEX software that is
either packaged with the
ExtremeXOS software or provided as a separate modification file. The
different image files are distinguishable by their file extension:
- .xos—ExtremeXOS CB-only image file
(example: SummitX-22.6.0.19.xos ).
- .xmod—ExtremeXOS modification file with
VPEX software for the BPEs (example: SummitX-22.6.0.19-vpex-bpe-1.1.0.41.xmod).
Starting with
ExtremeXOS 30.2, the diagnostic
image is in a separate xmod file (example: onie-30.2.2.x-vpex_bpe_diag-1.0.0.1.xmod)
that is not included in the regular BPE xmod or combined list files, but is installed on
the BPE at the factory. We anticipate that you will not generally need to update this
image.
- .lst—Combined ExtremeXOS CB software and VPEX BPE
file (example: summitX-22.6.0.19-vpex_controlling_bridge.lst).
For complete information about how to perform a software upgrade, see the Software Upgrade and Boot Options chapter.
There are two methods for upgrading BPEs:
- Automatic—The advantage of
automatically upgrading BPEs is that it is easier than manual upgrading, and does not
require manual intervention.
- Manual—You can upgrade devices
individually at a time of your choosing. The disadvantage is that you must initiate the
upgrade manually on each CB and BPE.
Automatic Upgrading
Upgrading automatically uses .lst files, so that the CB and BPEs are
upgraded together to ensure that all hardware is up-to-date.
When the upgrade is performed, the CB is upgraded (requires a reboot), and
when the BPE boots up, it performs a version check. If the BPE image is up-to-date, the BPE
progresses to the operational state. However, if the BPE image needs to be upgraded, the BPE
retrieves the software image file from the CB, upgrades itself, and then reboots.
Starting with
ExtremeXOS 30.5, an improved version
of automatic upgrading is available for MLAG/redundant CB configurations. You can reboot
each CB sequentially, rather than rebooting both simultaneously, avoiding the loss of
network connectivity. To use automatic upgrading, ensure that:
- Both CBs are running the same ExtremeXOS and
BPE xmod version.
- ISC connectivity is present (required
for information exchange between CBs during upgrade).
- Ensure that automatic upgrading is
enabled (default behavior). Use the show vpex command to see if automatic upgrading
is enabled. If not enabled, use the enable vpex
auto-upgrade command to enable it.
- On the first CB, install the .lst
image. After installation, reboot the first CB.
- After the first CB has finished
rebooting and has synchronized all of the slot and ring information, on the second CB,
install the.lst image, and then reboot it.
If you do
not have automatic upgrading enabled
when using redundant CBs, and a BPE image upgrade is needed, you must reboot both CBs
simultaneously. Simultaneous reboot is required because sequential rebooting (waiting for
each to come fully operational before proceeding to reboot the other) maintains BPE
connectivity. Because the BPE does not re-attach, it is not upgraded if needed.
After an upgrade occurs, the log shows messages similar to the following
indicating that the BPE has been upgraded:
08/04/2017 17:57:25.69 <Info:HAL.Card.Info> Slot-1: VPEX BPE slot 100 Active image VER 1.1.0.41
08/04/2017 17:53:44.52 <Info:HAL.Card.Info> Slot-1: Upgrading VPEX BPE slot 110 image from ver 1.1.0.40 to 1.1.0.41
08/04/2017 17:53:43.70 <Info:HAL.Card.Info> Slot-1: VPEX BPE slot 120 Active image VER 1.1.0.40
Manual Upgrading
For manual upgrading, you update each CB and BPE image individually in a “rolling”
fashion.
To manually upgrade:
- Upgrade ExtremeXOS on your first CB using
.xos image file (install image, and then reboot); do not install xmod.
- For redundant CB topologies, repeat
1 for each redundant CB.
- Install the xmod on each CB, and then
reboot each BPE one at a time, using reboot slot BPE slot on the master
CB, allowing the upgrade and initialization to complete for each BPE before proceeding
to the next.
To determine which CB
is the master, use the
show vpex
ports {ports_list} command. The switch with the M flag
is the master CB.
Rebooting
a BPE tears down the connection to any additional BPEs that are cascaded from that
BPE, so proper redundancy planning is required.
